Date/Time: Sun, 19 May 2024 09:47:39 +0000
Daily Pivot Point Consistency
View Count: 1636
[2015-03-16 16:37:30] |
User72407 - Posts: 31 |
Greetings, I have two chartbooks. One has daily candle charts, hourly, 15, 5, 2 minute. The daily pivots are on the 15 minute chart and match the pivots generated by the Hoffman Professional package, verified with them. The other chartbook has a daily candle chart, daily line chart, daily 2 and 5 min charts. I only use the 2 min chart and the daily pivots do not match what is shown in the 15 min chart in the other chartbook. Please see the attached screen shots. They are significantly different. The settings are identical, as also seen in the attachment. How can I get the daily pivot on the 2 minute chart to match the other chartbook? Thanks, Dan |
Pivot Points.docx - Attached On 2015-03-16 16:33:42 UTC - Size: 121.34 KB - 351 views |
[2015-03-16 20:01:17] |
Refer to this page here: Pivot Points are not Accurate or are Different Also when posting a chart image only use this method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-16 22:47:23] |
15 minute chart with daily pivots (I believe these to be accurate) http://www.sierrachart.com/image.php?l=1426541580287.png 2 minute chart with pivots (These appear to be wrong, but right or wrong, they are different from above) http://www.sierrachart.com/image.php?l=1426545293178.png These two charts are in different chartbooks. I will attach a word document with shots of the settings I have. Thanks |
Daily pivots for Sierra charts.docx - Attached On 2015-03-16 22:46:06 UTC - Size: 193.11 KB - 335 views |
[2015-03-17 00:31:50] |
You need to set the Reference Daily Chart For Data input to Yes.
[2015-03-17 00:51:42] |
Something so simple. It worked perfectly, thanks!
