Date/Time: Sun, 19 May 2024 09:16:48 +0000
Can't find Symbol
View Count: 905
[2015-03-16 14:52:37] |
EthanC - Posts: 44 |
Hi, Unable to find this symbol Description: 30-Day Fed Funds (P) Symbol: FF Date Time Of Last Edit: 2015-03-16 14:52:47
[2015-03-16 19:56:54] |
We see you are using Rithmic. So we will set this up on Rithmic.
[2015-03-17 09:25:01] |
Hi, Have you guys set it up, because I still could not find it. Thanks. |
[2015-03-17 10:08:58] |
Not yet. We should get to it later today.
[2015-03-18 04:00:59] |
This symbol has now been added for Rithmic. It is listed as ZQ.
[2015-03-18 15:00:32] |
Hi, I still can't find the Symbol. Kindly refer to attached. |
Untitled.png / V - Attached On 2015-03-18 15:00:05 UTC - Size: 14.66 KB - 274 views |
[2015-03-18 15:03:30] |
Oh ok, I found it after updating SC
