Date/Time: Sun, 19 May 2024 11:41:32 +0000
AskV-BidV and Range bar data inquiry
View Count: 1036
[2015-03-16 03:51:40] |
User268838 - Posts: 1 |
Hi, There seems to be a very large blank space on top and below AskV-BidV data and therefore its significantly reducing the charting space. How do I get rid of this empty space? Also, the range bar(standard) data is slightly different from my other trading platform. Does this have to do with data feed provider? Thank You |
[2015-03-16 04:14:42] |
1. Select Chart >> Reset Scales. If you need more help we need to see an image of the chart to better understand this. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image 2. Refer to help topic 47: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-16 04:15:59
[2015-03-16 13:10:46] |
User60518 - Posts: 106 |
I think I know what the original poster means - mine is the same: http://www.sierrachart.com/image.php?l=1426511277712.png There us a lot of dead space within the Number Bars Calculated Values study - can this be reduced? resetting scales does not reduce this space? Cheers Date Time Of Last Edit: 2015-03-16 13:11:49
[2015-03-16 19:53:28] |
You need to reduce the height of that chart region following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartWindowandRegions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
