Date/Time: Sun, 19 May 2024 05:06:59 +0000
Documentation for "Color ZigZag Line Using" and possible Multi-line Label bug
View Count: 1201
[2015-03-15 14:41:58] |
User87744 - Posts: 22 |
Hi, I'm unable to find documentation for the "Color ZigZag Line Using" input in the Zig Zag study. "Slope" is self-evident, but would like some info regarding "confirmed volume" and "trend confirmed volume". Can you point me to the right place, please? Secondly, when "Use Multi-Line Labels" is set to yes, the study appears to be adding 5 ticks to the text label offset on the swings high (but not on the swings low). I've uploaded a screen grab showing this. FYI, I have the study set to "tick offset". Is this a bug? If not how can I fix it so the text offsets on the swings high and low are equidistant when using multi-line labels? |
zigzag.png / V - Attached On 2015-03-15 14:37:36 UTC - Size: 24.87 KB - 400 views |
[2015-03-15 23:21:31] |
We are reviewing this. The documentation will be updated.
[2015-03-16 18:13:49] |
Al SC Developer - Posts: 434 |
The text offsets will be addressed in the next version.
