Date/Time: Sun, 19 May 2024 10:52:30 +0000
Window Number in title bar
View Count: 1403
[2015-03-14 19:56:07] |
trader1 - Posts: 128 |
Hi, Can you please tell me how the window number in the title bar in determined? Also, is there any way to change a window number? Thanks. |
[2015-03-15 22:59:31] |
When a chart is opened, the next lowest available number is used. It is not possible to change the chart number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
