Date/Time: Sun, 19 May 2024 06:24:53 +0000
Auto tracking highs and lows with horizontal lines
View Count: 2315
[2015-03-14 13:54:29] |
Litz - Posts: 131 |
Was wondering if there is a method of auto tracking a candle when it closes at new daily high or low whereby a horizontal line would be placed where the most recent high or low occurs, then left if not violated. Just noticed metastock has an indicator http://www.metastocktools.com/MetaStock/HiLo.txt Date Time Of Last Edit: 2015-03-14 14:04:46
[2015-03-15 23:32:39] |
Look at the Daily OHLC study.
[2015-03-16 12:18:05] |
Bob77 - Posts: 17 |
I am looking for a similar thing: have the Daily OHLC study draw the daily high and low on an intraday chart, but when a new high/low is made, instead of moving the whole horizontal line to the new level, draw it there using a stairstep. The result should be a channel of the current valid daily high/low, that is expanded when a new high/low is made.
[2015-03-16 19:45:27] |
This is supported with the Daily OHLC study. You need to set Graph High/Low Historically to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-17 00:30:27] |
cmet - Posts: 538 |
Take a look at the Daily Range Band study. Might be what you're looking for. |
