Date/Time: Thu, 17 Sep 2026 04:09:21 +0000
RLM-MM5 symbol not updating errors in log
View Count: 1287
[2015-03-12 23:01:58]
User726098 - Posts: 23
I rolled over to the new month RLM-MM5. The chart log shows the following error below. Chart has gaps and is basically a flat line. I'm on version 1234. I've deleted the old .scid file also and tried to download new data but same results.
Data Files path: C:\SierraChart\Data\ | 2015-03-12 17:44:58
OS Version Number: 6.1 | 2015-03-12 17:44:58
Locale Information: C | 2015-03-12 17:44:58
Checking for new symbol settings for oec | 2015-03-12 17:44:58
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-12 17:44:58
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-12 17:44:58
Symbol settings are up-to-date for oec | 2015-03-12 17:44:59
Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-03-12 17:45:00
OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-03-12 17:45:00
OEC FIX Trading socket (2) | Connected. | 2015-03-12 17:45:00
OEC FIX Trading socket (2) | Starting SSL connection. | 2015-03-12 17:45:00
OEC FIX Trading socket (2) | SSL connection established. | 2015-03-12 17:45:01
OEC FIX Trading: Sending the Logon message. | 2015-03-12 17:45:01
OEC FIX Trading | Connected to trading server. | 2015-03-12 17:45:01
Open E Cry FIX | Connecting to market data server prod.openecry.com:9301. | 2015-03-12 17:45:01
OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-03-12 17:45:01
OEC FAST Data socket (3) | Connected. | 2015-03-12 17:45:01
OEC FAST Data: Sending the Hello message. | 2015-03-12 17:45:01
OEC FAST Data: Sending the Logon message. | 2015-03-12 17:45:01
Open E Cry FIX | Connected to the market data server. | 2015-03-12 17:45:01
Open E Cry FIX | Connected. | 2015-03-12 17:45:01
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-12 17:45:04
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-12 17:45:04
Open E Cry FIX | Starting real-time market data updates for: YMM5. ID: 1 | 2015-03-12 17:45:07
Open E Cry FIX | Starting real-time market data updates for: ESM5. ID: 2 | 2015-03-12 17:45:07
Open E Cry FIX | Starting real-time market data updates for: RLM-MM5. ID: 3 | 2015-03-12 17:45:07
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RLM-MM5.scid | 2015-03-12 17:45:07
Intraday data recording state for symbol RLM-MM5 is set to download pending. | 2015-03-12 17:45:07
HD Request # 2 | Downloading Intraday chart data for RLM-MM5 to the file RLM-MM5.scid. Service: oec | 2015-03-12 17:45:07
Compressing file: C:\SierraChart\Data\RLM-MM5.scid. This may take a while. | 2015-03-12 17:45:07
HD Request # 2 | Download start Date-Time: 2014-09-07 17:45:07.0 | 2015-03-12 17:45:07
HD Request # 2 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 17:45:07
Socket (0) | Resolved address oec.sierracharts.com to IP 65.182.172.164 | 2015-03-12 17:45:07
Socket (4) | Connected. | 2015-03-12 17:45:07
HD Request # 2 | Sending historical data logon request message. | 2015-03-12 17:45:07
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-09-07 17:45:07. Record interval: 0. Symbol: RLM-MM5 | 2015-03-12 17:45:08
HD Request # 2 | Decompressing data. | 2015-03-12 17:45:08
HD Request # 2 | Receiving Intraday data for RLM-MM5 starting at 2014-11-19 09:41:57 | 2015-03-12 17:45:08
HD Request # 2 | Timestamp of first Intraday data file record written: 2014-11-19 09:41:57 | 2015-03-12 17:45:08
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1192.000000, Prior Low = 1192.000000, High = 900.000000, Low = 900.000000, Time Difference = 1092 seconds, Percentage = 16.637999%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1192.000000, Prior Low = 1192.000000, High = 900.000000, Low = 900.000000, Time Difference = 1112 seconds, Percentage = 16.667999%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1215.000000, Low = 1213.000000, Time Difference = 3 seconds, Percentage = 300.089812%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1215.000000, Low = 1212.000000, Time Difference = 38 seconds, Percentage = 301.139998%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1212.000000, Time Difference = 89 seconds, Percentage = 302.670002%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.000000, Low = 1211.000000, Time Difference = 19 seconds, Percentage = 300.569963%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.000000, Low = 1211.500000, Time Difference = 10 seconds, Percentage = 300.300002%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1212.000000, Time Difference = 108 seconds, Percentage = 303.239989%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1212.500000, Time Difference = 13 seconds, Percentage = 300.389886%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1212.000000, Time Difference = 28 seconds, Percentage = 300.839853%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1212.000000, Time Difference = 161 seconds, Percentage = 304.830003%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.500000, Low = 1211.500000, Time Difference = 30 seconds, Percentage = 300.900006%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.000000, Low = 1212.000000, Time Difference = 3 seconds, Percentage = 300.090003%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.099976, Low = 1212.000000, Time Difference = 2948 seconds, Percentage = 388.439989%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.400024, Low = 1212.000000, Time Difference = 31150 seconds, Percentage = 1234.500027%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.300049, Low = 1211.900024, Time Difference = 31175 seconds, Percentage = 1235.249996%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.300049, Low = 1211.900024, Time Difference = 31195 seconds, Percentage = 1235.849953%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.300049, Low = 1211.900024, Time Difference = 31196 seconds, Percentage = 1235.879993%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.199951, Low = 1211.900024, Time Difference = 31225 seconds, Percentage = 1236.749935%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.199951, Low = 1211.800049, Time Difference = 31226 seconds, Percentage = 1236.779976%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.800049, Time Difference = 31250 seconds, Percentage = 1237.500000%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.900024, Time Difference = 31250 seconds, Percentage = 1237.500000%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.900024, Time Difference = 31250 seconds, Percentage = 1237.500095%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.699951, Time Difference = 31365 seconds, Percentage = 1240.950012%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.599976, Time Difference = 31366 seconds, Percentage = 1240.979958%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.199951, Time Difference = 31415 seconds, Percentage = 1242.449951%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.300049, Time Difference = 31427 seconds, Percentage = 1242.809963%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.400024, Time Difference = 31427 seconds, Percentage = 1242.809963%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.400024, Time Difference = 31427 seconds, Percentage = 1242.810059%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.300049, Time Difference = 31438 seconds, Percentage = 1243.139935%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.400024, Time Difference = 31438 seconds, Percentage = 1243.140030%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.400024, Low = 1211.199951, Time Difference = 31616 seconds, Percentage = 1248.479939%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.400024, Low = 1211.300049, Time Difference = 31616 seconds, Percentage = 1248.480034%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.300049, Time Difference = 31628 seconds, Percentage = 1248.839951%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.500000, Low = 1211.300049, Time Difference = 31628 seconds, Percentage = 1248.840046%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.599976, Time Difference = 33085 seconds, Percentage = 1292.549992%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1212.000000, Low = 1211.699951, Time Difference = 41969 seconds, Percentage = 1559.070015%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.800049, Low = 1211.699951, Time Difference = 41969 seconds, Percentage = 1559.070015%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1211.800049, Low = 1211.500000, Time Difference = 41969 seconds, Percentage = 1559.070015%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1214.199951, Low = 1213.800049, Time Difference = 44815 seconds, Percentage = 1644.449997%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1215.099976, Low = 1214.699951, Time Difference = 46404 seconds, Percentage = 1692.119980%. | 2015-03-12 17:45:08 *
HD Request # 2 | Historical error filtered for RLM-MM5, Prior High = 1.500000, Prior Low = 1.500000, High = 1215.300049, Low = 1215.199951, Time Difference = 47079 seconds, Percentage = 1712.369919%. | 2015-03-12 17:45:08 *
Socket (4) | Shutdown and closed. | 2015-03-12 17:45:08
The network socket for historical data has been closed. | 2015-03-12 17:45:08
HD Request # 2 | Received 17398 records from 2014-11-19 09:41:57 to 2015-03-12 16:59:51 (113.3 days) and wrote 1238 records for RLM-MM5 | 2015-03-12 17:45:08
HD Request # 2 | Intraday download COMPLETE for RLM-MM5. Completion time: 0s. Unique request ID: 1 | 2015-03-12 17:45:08
Removed historical data download ID 1 | 2015-03-12 17:45:08
Real-time Intraday chart data file updates started for RLM-MM5 | 2015-03-12 17:45:08
[2015-03-13 01:11:31]
The data errors for RLM-MM5 have been cleaned up.
Go to the chart and select Edit >> Delete All Data and Download.
[2015-03-13 01:20:48]
Yes that did it. Data looks good again! I appreciate the awesome support!
