Date/Time: Sun, 20 Sep 2026 05:28:14 +0000
CIRCLE/ELLIPSE TOOL
View Count: 1294
[2015-03-12 18:00:30]
michelh - Posts: 162
Can the Ellipse tool please be fixed so that the points defined are on the diameter of the circle instead of the corners?
If I try to draw an accurate arc between 2 points, this is not possible since the current tool defined the corners of a square with an embedded circle and NOT the actual perimeter/diameter of the circle.
This would be a very valuable cycle tool.
With thanks,
