Date/Time: Sun, 05 May 2024 22:20:45 +0000
Quoteboard font change
View Count: 1344
[2015-03-11 15:56:03] |
User22396 - Posts: 191 |
is there a place to change the font to bold for a quoteboard? I can change the font size just not able to adjust to bold in the global settings/graphics settings/fonts...which one controls the quoteboard? thanks |
[2015-03-11 17:15:06] |
We have to add this capability.
[2015-08-14 02:01:58] |
dd45 - Posts: 41 |
Has this been added? it is much needed
[2015-08-14 03:51:31] |
Yes it has. Follow the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#ChangingFont Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
