Date/Time: Sun, 19 May 2024 05:43:50 +0000
Problem
View Count: 860
[2015-03-11 15:45:01] |
C. Notes - Posts: 129 |
Hi, My futures GTC orders on IB are showing as DAY orders... Please Advise, Thanx, Y'all always rock |
[2015-03-11 16:59:10] |
Are these Attached Orders or the main order?
[2015-03-12 00:36:18] |
Attached Orders it looks like...
[2015-03-12 04:08:03] |
You need to set the Time in Force for those Attached Orders. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#TimeInForce Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-16 04:26:12] |
Hi, Ok....here's an update on the issue.... As of open this eve (morning to you) My orders were on the chart and showed GTC in TWS. Upon returning to my system the orders do not show on the SC chart but are still in TWS. I am trading DX JUNE |
[2015-03-16 05:40:34] |
And were the orders originally entered from Sierra Chart? If so, the only thing we know that might affect this, is the Instance setting in Global Settings >>Data/Trade Service Settings. Otherwise, contact Interactive Brokers about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-16 05:41:02
