Date/Time: Sun, 19 May 2024 06:11:19 +0000
Symbol Unknown
View Count: 846
[2015-03-09 15:36:45] |
User95104 - Posts: 2 |
Hi, I purchased the SC Exchange Data service and paid the CME exchange fees. When I log on the chart to stream ES, data doesn't stream and I got the symbol unknown message.
[2015-03-09 16:02:57] |
Sierra Chart - Max - Posts: 5618 |
You have indicated that TD Ameritrade is your broker, so you will need to follow the setup instructions here starting with steps #12: Sierra Chart Exchange Data Feed: Setup Instructions For step #14 Follow the TD Ameritrade setup instructions here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Sierra Chart Support Date Time Of Last Edit: 2015-03-09 16:03:20
[2015-03-09 16:36:39] |
Actually everything has already been set up based on the setup instruction. I tried to log into TD Ameritrade as its setup instruction but I couldn't log on, it says login error, unable to authorise access. My broker is actually ThinkorSwim which I believe is same at TD Ameritrade. I also note that Futures data is supported by TD Ameritrade which is why I purchase a separate futures data feed from SC. So am I getting the data feed from SC or TD Ameritrade? |
[2015-03-09 17:17:55] |
Since you are using the Sierra Chart Exchange Data Feed, the market data will come from Sierra Chart. Make sure you have the correct TD Ameritrade Username and Password in Global Settings >>Data/Trade Service Settings. The first step is to get connected to TD Ameritrade. Check with TD Ameritrade and confirm what your Username and Password is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
