Date/Time: Tue, 14 May 2024 07:51:32 +0000
New Spreadsheets INDIRECT function
View Count: 1046
[2015-03-09 01:49:04] |
Sawtooth - Posts: 3996 |
Would you please add the Excel equivalent of the INDIRECT function to the supported functions of the New Spreadsheets? |
[2015-03-09 17:12:36] |
We will look into this.
[2015-05-03 23:04:52] |
Thanks for adding this function, except it gives a #SYNTAX error with this: =INDIRECT("C"&"3") This syntax is needed/used to create a cell reference from 2 text sources. Even using an intermediate cell with this also give a #SYNTAX error: ="C"&"3" Both of the above work in the Old Spreadsheets. Date Time Of Last Edit: 2015-05-03 23:20:10
[2015-05-04 09:02:32] |
We will check on this.
[2015-05-04 21:59:48] |
Jeffrey - Posts: 2102 |
Use the '+' operator to combine two text values. Example: =INDIRECT("C"+"3") Reference: Spreadsheet Arithmetic Operators |
