Date/Time: Sun, 19 May 2024 05:06:38 +0000
W/E data messes with TPO lines
View Count: 831
[2015-03-08 15:32:39] |
User507545 - Posts: 4 |
Dear tech support dude, would you be able to resolve this issue of tpo lines being messed up after weekend. ive got my data/trade time settings at 5pm ny close and chart settings to open 1700 close 1659 but the little bit of weekend data messes with the lines. i know i can uncheck box to not load weekend data but would there be any other way of resolving this as that messes with the continuity of my charts. I uploaded an image to make it easier to understand :- http://www.sierrachart.com/image.php?l=1425828411903.png Any help much appreciated Cheers C |
[2015-03-08 18:58:39] |
If you do not want weekend data being used, then you have to uncheck the option not to load weekend data.
