Date/Time: Sat, 18 May 2024 22:26:23 +0000
Emailed Question
View Count: 1096
[2015-03-05 23:52:06] |
Sierra Chart - Max - Posts: 5618 |
Hi I use sierra chart , can you tell me when I enter a trade or close a trade I hear no sound , is it possible to hear sounds with Sierra chart and if yes where can I activate it?
Sierra Chart Support |
[2015-03-06 00:25:59] |
Kiwi - Posts: 375 |
User response: Check >> Trade >> General Trade Settings http://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html http://i.imgur.com/9s4NgYh.png You can set alerts for actions. Make sure that the alert has a sound file associated with it and try playing it. Mine said OrderFilled was the sound file which didnt play so I selected OrderHasBeenFilled instead and all was well. Might be your issue. >> Global Settings >> General Settings >> Alert/Gen3 tab http://i.imgur.com/0hb7XIm.png My favourite sound is Alert 22 :-) Date Time Of Last Edit: 2015-03-06 00:28:03
[2015-03-06 03:56:42] |
Sierra Chart can provide an Alert when an order is filled. The documentation for this is on the Global Trade Settings page: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#GeneralTradeSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
