Date/Time: Sat, 18 May 2024 19:29:38 +0000
alert
View Count: 1094
[2015-03-05 17:43:02] |
julian pineda - Posts: 60 |
i want a vertical line every time it pass 40 bars. how I do that?
[2015-03-05 18:21:17] |
It is possible to set up a Vertical Grid every 40 bars. Refer to the Chart Settings documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-09 07:30:03] |
inverter - Posts: 42 |
How do I change alert sounds? Whatever you paid alert is always the same sound.-. executed order
[2015-03-09 16:06:42] |
Sierra Chart - Max - Posts: 5618 |
To change and set custom alert sounds refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support |
