Date/Time: Sun, 19 May 2024 02:02:35 +0000
GetStudyExtraArrayFromChartUsingID
View Count: 1014
[2015-03-05 16:44:16] |
User53601 - Posts: 105 |
Hello, I try to display a Value from study in other chart with this code: SCFloatArray ExtraArrayFromChart ; sc.GetStudyExtraArrayFromChartUsingID(2, 17, 2, 4, ExtraArrayFromChart); TextDelta3.Format("Value: %d \n", ExtraArrayFromChart[1] ); // integer value However seems not doing what I am expecting. I am not sure whether to use SCFloatArray or SCFloatArrayref. I see different definitions: Here with SCFloatArray http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetStudyExtraArrayFromChartUsingID and here with SCFloatArrayRef - in 1000 Release Date: 2013-07-26 http://www.sierrachart.com/index.php?page=doc/Whats_New.php&p=4 Thank you |
[2015-03-06 19:06:17] |
You will need to use SCFloatArray. Also do you really want to get one of the extra arrays or one of the Subgraph arrays? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-08 20:04:57] |
thank you, helped.
