Date/Time: Sun, 20 Sep 2026 03:45:27 +0000
How to use Sierra through my broker
View Count: 1201
[2015-03-05 16:39:11]
Maharishi - Posts: 8
Until now I have been purchasing time directly from Sierra. I now pay my broker Amp Futures a for Sierra but don't know how this works in practice. Can you please advise?
[2015-03-05 18:27:48]
They will give you a Sierra Chart Account Name. Refer to the documentation here to use it with your installed copy of Sierra Chart:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
[2015-03-05 19:06:49]
Hi
Thanks for your reply. I have done as you suggested but m still not able to use Sierra. I have copied and pasted the log below:
Software version: 1227 | 2015-03-05 19:01:25
Uses New Spreadsheets | 2015-03-05 19:01:25
Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2015-03-05 19:01:25
To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2015-03-05 19:01:25 *
Received 1 data feed usernames. | 2015-03-05 19:01:25
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-03-05 19:01:25
Active service: CQG FIX Trading | 2015-03-05 19:01:25
Time Zone: +00:00:00 (UTC+00) | 2015-03-05 19:01:25
2015-03-05 19:01:25 Local computer clock time | 2015-03-05 19:01:25
2015-03-05 19:01:25 GMT time | 2015-03-05 19:01:25
2015-03-05 19:01:25 Time zone adjusted time | 2015-03-05 19:01:25
Program path: C:\SierraChartOEC\ | 2015-03-05 19:01:25
Data Files path: C:\SierraChartOEC\Data\ | 2015-03-05 19:01:25
OS Version Number: 6.2 | 2015-03-05 19:01:25
Locale Information: C | 2015-03-05 19:01:25
Checking for new symbol settings for cqg | 2015-03-05 19:01:25
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-05 19:01:25
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-05 19:01:25
Symbol settings are up-to-date for cqg | 2015-03-05 19:01:25
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2015-03-05 19:01:30 *
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-05 19:01:30
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-05 19:01:30
[2015-03-05 19:17:23]
Sierra Chart - Max - Posts: 5968
Contact AMP immediately and ask them to change the password on your live account. PLEASE avoid posting your AMP credentials on public forums.
Note that we have hidden your above post.
Sierra Chart Support
Date Time Of Last Edit: 2015-03-05 19:18:08
[2015-03-05 20:13:06]
Thanks. I forgot this was public. I have changed the password. Still, if I try to login using it I get an 'Unkown Server Error' message and the log tells me that my account does not support this package etc.
[2015-03-05 20:30:27]
We have fixed the Unknown Server error and we have activated your Sierra Chart account. Restart Sierra Chart.
Make sure you are logging into Sierra Chart using the same Account Name that you have logged into this Support Board with.
Here are the CQG set up instructions:
CQG Trading Platform Service: Setup Instructions
Date Time Of Last Edit: 2015-03-05 20:31:11
