Date/Time: Sat, 18 May 2024 20:37:20 +0000
Interactive Brokers New Continuous Future Chart Symbol
View Count: 1359
[2015-03-05 03:32:13] |
User32803 - Posts: 18 |
Can the new continuous future chart symbols be used in Sierra Chart to have continuous contracts? If yes, what futures format should be used for say, the emini S&P on Globex?
[2015-03-05 18:17:47] |
We are not sure what symbols you are referring to. But Sierra Chart has its own Continuous Futures Contract feature which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Use that feature only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
