Date/Time: Sun, 19 May 2024 02:57:39 +0000
add 'currency value per tick' as J56 in regular spreadsheet
View Count: 783
[2015-03-05 02:35:54] |
User22396 - Posts: 191 |
possible to add to normal spreadsheet study as j56 or j22? or is there a study that I can add to a chart to then use in a spreadsheet? thanks Date Time Of Last Edit: 2015-03-05 02:38:54
[2015-03-06 18:38:22] |
This will be supported in the next release when using New Spreadsheets.
