Date/Time: Sun, 19 May 2024 06:25:00 +0000
Is there and order type SendAttachedOrdersByPosition for ASCIL
View Count: 908
[2015-03-04 22:22:26] |
CMG - Posts: 179 |
I am using the cancel all working orders on exit = yes as I have both attached orders and spreadsheet for trading, sometimes the attached positions of open orders get erased. I was wondering if I can code a study just to send attached orders for open positions when the study does not find attached ones. It seems like all attached positions are parent of the buy/sell order. However you have the feature SendAttachedOrdersByPosition or Price. Do you have that order type for ASCIL or can I send attached orders without a parent order? http://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#SendAttachedOrders PV [support women that code] |
[2015-03-06 18:40:08] |
In ACSIL it is not possible to send the defined attached orders based on the current position like you can in the user interface.
