Date/Time: Sat, 18 May 2024 19:03:19 +0000
user drawn tools line numbers
View Count: 963
[2015-03-04 20:55:19] |
onnb - Posts: 661 |
Just wanted to confirm that tools that are drawn from the UI manually by the user are given negative line #'s that start at 0 0, -1, -2, etc. |
[2015-03-04 21:01:25] |
onnb - Posts: 661 |
I also noticed that the docs no longer have this method: GetChartDrawing I'm looking at this page - http://www.sierrachart.com/index.php?l=doc/doc_ACSILDrawingTools.html I see that in version 1226 it was renamed. "Renamed sc.GetChartDrawing to sc.GetUserDrawnChartDrawing in ACSIL." I'm looking in the source code on version 1235 and I see that GetChartDrawing is defined while GetUserDrawnChartDrawing is not defined. This is a bit confusing ;) Date Time Of Last Edit: 2015-03-04 21:10:47
[2015-03-04 21:47:30] |
The renaming of that function was not complete and we are fixing this now. Thank you for pointing this out. It should be sc.GetUserDrawnChartDrawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-04 21:47:40
[2015-03-04 21:49:39] |
User drawn drawings from the user interface will have a negative LineNumber and they will always be nonzero.
[2015-03-05 01:33:40] |
onnb - Posts: 661 |
I am seeing that the first drawn object on the chart has a LineNumber of zero. I am on build 1235. Date Time Of Last Edit: 2015-03-05 01:34:03
[2015-03-05 01:44:52] |
We need to fix this.
