Date/Time: Sat, 18 May 2024 15:24:37 +0000
VBP study - 'Heatmap' colours reset to all bue since upgrade
View Count: 953
[2015-03-04 13:47:09] |
User60518 - Posts: 106 |
Hi, Since I upgraded to version 1239 (forced due to transact issue) my volume by price 'heatmap' settings have reset all levels to: R:0, B:0, G:200 Any way to reset to the rainbow colors? Cheers |
[2015-03-04 19:20:10] |
You have to manually change the colors and going forward they will not change.
[2015-03-05 01:36:19] |
Thanks - can you tell me what the default colour settings were before the change? Cheers |
[2015-03-05 01:44:40] |
You can tell just by adding a new Volume by Price study to the chart.
