Date/Time: Fri, 20 May 2022 17:43:47 +0000
Quoteboard functionality
View Count: 1175
[2013-05-28 11:01:59] |
EuropeanTrader - Posts: 290 |
Hi, is there a way I can connect a symbol in a quote board with a chart so once I click on the symbol it changes existing symbol on my chart? thank you |
[2013-05-29 01:29:27] |
M5amhan - Posts: 468 |
go to chart settings>advanced settings 2 then set your link number and check link symbol. then go to your quoteboard and click settings>set chart link and click on the same number as your chart. you can do this for as many charts as you need with the same link number |
[2013-05-29 02:25:25] |
Yes. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#ChangingSymbolOfChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-29 13:22:19] |
thx to both of you
