Date/Time: Sun, 05 May 2024 16:44:01 +0000
[Locked] - Extend Trial to more 30 days
View Count: 3690
[2015-03-02 12:23:07] |
User57819 - Posts: 4 |
Hi, I had some difficulty in adapting to Sierra Chart but it really is an impressive platform. I'm trying to create some indicators to let the Multicharts and move to the Sierra Chart but I'm taking longer than I would therefore request an extension of the trial version for 30 days more, if you please. So that I can evaluate Sierra Chart features for future subscription. Thank you, Bruno Neves |
[2015-03-03 06:57:23] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-24 01:18:28] |
User432686 - Posts: 2 |
Hi, I'm almost finished developing an ACSIL program that I need to test. May I please request another 30 days extension as well? Thank you in advance! |
[2018-04-24 05:31:47] |
Contact us here about this: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-30 21:48:44] |
Michael W - Posts: 20 |
Hi I am asking for an extension of the 15 day trial (another 15 days) applied for thru AMP brokerage. It took me a bit longer to get my account approved as it is an entity account and it is now approved. My Sierra Chart trial is set to expire May 3rd, I am going to fund the account tomorrow but it takes a few days to get everything credited and set up, so I would appreciate an extension if possible Thank you |
[2018-05-01 01:36:05] |
This time extension has been done.
[2018-08-10 00:49:38] |
User758078 - Posts: 2 |
Hi, Would like to receive a trial extension. Sierra Charts was initially lagging for me & have just downloaded a new version. Thanks. |
[2018-08-11 00:28:46] |
Your Sierra Chart account is active until August 24.
[2019-09-03 00:30:07] |
User486055 - Posts: 8 |
may I also have a 15day extension please, thanks
[2019-09-03 01:37:10] |
Trial length is 15 days. But we have added another 7 days to your account.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-03 01:37:28
[2020-03-05 16:07:35] |
Trac - Posts: 5 |
Hey, may I get a trial extension. Want to test some programs before making the switch to sierra chart. Thanks in advance. |
[2020-03-05 17:05:17] |
John - SC Support - Posts: 31379 |
With regards to post #11: Your trial time has been reset, therefore you have the trial available until March 20, 2020. After that time, you will need to make a payment and set a package for the renewal of Sierra Chart. You can make a payment here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-19 10:57:33] |
User542688 - Posts: 5 |
Hi Can you please extend the trial extension for approx. 15 days more? |
[2021-04-19 15:48:51] |
User542688: You just started your Trial, therefore there is nothing to extend. We allow 1 15-day trial in a 12 month period. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-20 02:47:39] |
StarLight - Posts: 26 |
Hi there, I would like to request for a 15 days trial period. Greatly appreciated. Thanks. |
[2021-04-20 14:10:01] |
StarLight: We have reset your trial, which now starts today. It will end on May 5, 2021. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-26 00:19:30] |
User818415 - Posts: 5 |
Hello, I'm making my way through most of sierra chart features but would like to request a trial extension if I could. Thank you |
[2021-05-26 13:50:57] |
User818415: We can not extend your trial time, as you have already used the allotted amount of time (15 days). In order to continue to use Sierra Chart, you will need to select a Service Package. Refer to the instructions here: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
