Date/Time: Sun, 28 Apr 2024 19:22:47 +0000
Volume chart messed up when enabling "Record true real-time data
View Count: 2203
[2013-03-26 06:38:41] |
traderleong - Posts: 12 |
To get around phantom huge volume bar problem when using simulated trades for IB data feed, I was told to enable the option "record true real-time data in intraday charts". Now a 5min or 10 min chart look fine, but the volume chart looks messed up and it will not plot each for specified volume any more. Please see the attached chart below. http://www.sierrachart.com/image.php?l=1364279852351.png |
[2013-03-26 20:26:57] |
Many of my volume bar charts have the mentioned problem. Each bar is plotted for about one minute data instead of the specified volume. I wanted a volume bar chart but instead I got a one-minute bar chart. Can this be fixed?
[2013-03-26 21:26:38] |
Yes. There is a solution. Please refer to this section in help topic 47 here: http://www.sierrachart.com/index.php?l=doc/helpdetails47.html#NumberofTradesorVolumeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-27 00:20:05] |
It works. Thanks for the great help. One more question: should I use "1 tick" as IB intraday data storage time limit in the data/trading service option? |
[2013-03-27 00:31:31] |
Yes.
