Date/Time: Wed, 01 May 2024 14:35:01 +0000
[User Discussion] - Feature Request: Integration with BookMap
View Count: 2829
[2015-02-28 04:02:12] |
cmet - Posts: 536 |
This platform has become a very popular/powerful tool for intraday traders and is now used by many pros. http://www.bookmap.com Any chance it can be integrated to work with Sierra Chart (without having to have a separate platform running to feed the data) or similar functionality created for SC? Probably the clearest view of the book in real time created to date. Date Time Of Last Edit: 2015-02-28 04:03:49
[2015-02-28 22:15:21] |
Have them refer to the DTCProtocol.org website. Sierra Chart supports the DTC Protocol both as a Client and Server. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DTC_TestClient.php https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-25 17:31:29
[2015-09-25 13:55:30] |
User75949 - Posts: 108 |
yes the bookmap is a very interesting piece of software, even if not integrated is there any chance sierra could introduce some study or feature to track limit orders evolution? this is the next level of order flow study, in the next future it will become a must like it happened in the last years with the inftroduction of volume profile studies, the footprint (number bars in sierra) and the delta volume. |
[2015-09-25 15:27:35] |
also something similar to TINT of LINSOFT https://www.linnsoft.com/techind/tint could be very useful |
[2015-09-25 17:03:53] |
crazybears - Posts: 314 |
Hi if you are elite member of BMT forum search for : [SC] Record of DOM size on chart [SC] Filtered DOM |
[2015-09-25 17:33:21] |
We updated post #2 with additional information to make a clear as to what we were referring to when we referred to the DTC Protocol website.
[2015-09-27 07:50:25] |
...unfortunately I'm not an Elite member of BMT... don't you have these information somewhere else? by the way is there any chance to have this kind of feature on SC? does anyone already coded it or not? are you planning to insert it in the next versions? tks regards |
[2015-09-27 13:57:14] |
i advice to subscribe , it's worth. I'll try to do something similar but one thing to keep in mind, I don't know any data feeds except maybe nanex that have historical DOM available.ok cme sell it but it's a bit pricey. |
[2015-09-28 09:39:13] |
tks user666, are you working on it to implement it in SC? well for the historical is not a big problem, il could be enough to make it work with a database on the pc that starts as soon as you switch on the pc and the datafeed... this is a tool that is useful in the very short term so if our history starts from when the pit time starts, when we switch on the pc it's fine. tks |
[2015-11-22 17:30:13] |
User167108 - Posts: 49 |
+1 for Bookmap integration
