Date/Time: Sun, 19 May 2024 04:55:45 +0000
Questions about replay and chart
View Count: 985
[2015-02-27 14:20:06] |
User38993 - Posts: 61 |
Questions: 1. For replay, everything works fine, but Matrix resting orders do not show. Is this normal? 2. Is it possible to change colors of following (attached image)Shor order fills arrow? |
Capture_2015_02_27_23_10_51_971.png / V - Attached On 2015-02-27 14:19:56 UTC - Size: 5.65 KB - 446 views |
[2015-02-27 22:34:30] |
1. We do not understand this. 2. Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-12 11:59:27] |
For question 1, when replaying, attached information isn't showing (resting orders) |
Capture_2015_03_03_03_07_53_130.png / V - Attached On 2015-03-12 11:59:24 UTC - Size: 13.67 KB - 300 views |
[2015-03-12 19:34:04] |
Make sure the correct Trade Account is selected: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SelectingTradeAccount And make sure Trade >>Only Orders from Chart is not checked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-14 10:37:31] |
I think you might not have understood the problem correctly. When I replay, for matrix only 1 for bid 1 for ask show, not the whole picture which I attached earlier. Look at the attached photo. Is this normal?
Capture_2015_03_14_19_33_04_905.png / V - Attached On 2015-03-14 10:37:07 UTC - Size: 56.01 KB - 309 views |
[2015-03-15 23:33:06] |
Market depth is not available during a replay.
[2015-03-19 08:04:10] |
can you take a look at this problem? my main 100 volume chart's price is different from other charts. Why is this happening? This happens on market replay |
Capture_2015_03_19_17_02_20_634.png / V - Attached On 2015-03-19 08:03:57 UTC - Size: 82.29 KB - 283 views |
[2015-03-19 08:38:44] |
Possibly the Session Times in Chart >> Chart Settings are filtering out the data for the charts which do not match.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-19 08:45:51
[2015-03-19 08:43:53] |
aww timezone difference seems to be the problem. now solved
