Date/Time: Sat, 18 May 2024 15:41:04 +0000
Absence (hole) quotation
View Count: 823
[2015-02-27 08:14:02] |
User68127 - Posts: 23 |
Hello at the opening of SierraCharts I miss quotations. This morning, for example, opening at 8:50 am on Future CAC 40 (PIL-CQG Fix) but no quotation 8:34 to 8:50 am Graphic in 2 minutes. thank you for your help |
[2015-02-27 22:13:46] |
For some symbols like the CAC 40, historical data is delayed about 10 to 15 minutes. So what you describe does make sense. There is a workaround for this. Refer to this thread: Helpful Trick to Solve 10 Minute Delayed Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
