Date/Time: Sat, 18 May 2024 15:00:39 +0000
Volume by price retracts
View Count: 2262
[2015-02-27 02:18:29] |
AC95097 - Posts: 5 |
Good morning, just recently I started having problems with Volume By Price study. Once the charts start “moving” (live feed or replay), the volume bars start retracting until they make an even line on the right side of the chart. As seen on this video: https://vimeo.com/120757568 If I refresh the study or make any change to it (like hide it and then enable it back again) it starts OK, but then the volume bars retract again. I am not aware of making any changes to the study settings. Thank you for your help. Josef |
[2015-02-27 02:28:25] |
This is quite unusual. We do not need to see a video. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-27 02:45:17] |
Here it is. http://www.sierrachart.com/image.php?l=1425005080842.png |
[2015-02-27 02:55:04] |
Post an image of only one chart Only containing the Volume by Price study. And let us know what the Volume Graph Period Type input is set to for the volume by price study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-27 03:03:15] |
http://www.sierrachart.com/image.php?l=1425005997980.png Volume Graph Period Type: Multiple Profiles Fixed By Time |
[2015-02-27 08:45:37] |
Could you provide us a Chartbook with one chart containing the Volume by Price study which demonstrates the problem. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-27 08:46:02
[2015-02-27 14:13:42] |
Sure, there you go...
[2015-02-27 17:00:37] |
I've changed the Number Of Periods Back To Reference input from 1 to 0 and now the study works just fine. Sorry to bother you. Best, Josef |
[2015-02-27 22:29:40] |
We will look into this.
