Date/Time: Sat, 18 May 2024 15:00:42 +0000
Analysis window doesn't show custom study used checked off anymore?
View Count: 772
[2015-02-26 15:01:18] |
The Stealthy Trader - Posts: 162 |
So, not sure if it's because I remoted in to my Sierra setup this past week but I seem to have lost the invaluable checkmark indicating which of the +100 custom study's I'm using for any particular window/stock chart. Usually when I open the click on the Analysis tab, I immediately see a check mark next to the study indicating that it's being used for this window.. But this isn't showing any more for any of my windows in any of my chartbooks. Please advise. X version: 1220 |
[2015-02-26 18:26:30] |
We tested this and it works. Nothing has changed with this. Reselect the study collection from the Analysis menu and you should see the checkmark.
[2015-02-27 16:16:54] |
hmm, so indeed it works over here too..that is after I re-select the right custom study. But to do so, I'll have to review over +100 windows to accomplish that. And that's quite the daunting task. Can you inquire as to whether or not I inadvertently clicked something in the spreadsheet settings or somewhere on the platform that might have caused me to lose all my checkmarks? That would be greatly appreciated.. Thanks, J. Date Time Of Last Edit: 2015-02-27 16:17:32
