Date/Time: Sat, 18 May 2024 22:04:04 +0000
[User Discussion] - Fractal Study by Bill Williams
View Count: 1367
[2015-02-25 22:47:47] |
User94740 - Posts: 333 |
Hi SC, my information regarding probably the most basic of Bill William's fractal studies indicates an up-fractal results when the third time occurrence of five consecutive time occurrences is higher than the two time bars prior and the two time bars after. The down-fractal is the opposite. Maybe I am wrong, but the attached pic shows with the help of the arrows, fractals according to my understanding which are missing. http://www.sierrachart.com/image.php?l=142490433720.png |
[2015-02-26 02:18:05] |
This is not an area of development we want to get involved with. The source code for this study is provided and can be modified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-26 02:18:30
[2015-02-26 02:58:44] |
Here is the documentation to modify Sierra Chart source code: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
