Date/Time: Sat, 18 May 2024 21:06:19 +0000
Study ID on volume Profile disappeared
View Count: 1107
[2015-02-25 15:21:04] |
User60287 - Posts: 19 |
I can no longer display the study ID at the top of the volume profile tool after Feb 24 update. Please advise
[2015-02-25 18:04:31] |
We will look into this and resolve it.
[2015-02-25 22:04:11] |
In the next release this will be solved but the way to see the study ID is to set Entire Profile Text Display to Study Name and ID.
[2015-02-26 13:34:12] |
I installed update 2.26.15. Every volume profile now has the same ID: 141. Is this "entire text display" the end game for identifying profiles? Can there be just the ID shown?Please?
[2015-02-26 19:34:15] |
More work is being done on the Entire Profile Text Display setting for the Volume by Price study.
[2015-03-08 15:44:47] |
Thanks for separating the Profile nomenclature. Displaying just the profile ID still returns all profiles with "141" ID. Please advise.
[2015-03-08 18:55:06] |
That is expected. If you are displaying the study ID, then of course the study ID will be displayed on every profile that the study instance creates.
[2015-03-08 21:15:55] |
A couple of versions ago, choosing to display the study ID on the volume profile returned a unique number to that individual profile that could be easily referenced for manipulation in the Studies to Graph pane of the Chart Studies window. The unique ID number is still assigned to the VP in the Studies to Graph pane but I cannot reproduce that unique number visually at the top of my VP in the chart. Please help me choose the correct settings as I cannot figure it out. All I get is "141" on every VP. What is "141"?
[2015-03-09 16:25:48] |
We understand the problem now. We used the internal study identifier rather than what is called the unique instance identifier. This will be fixed in the next release. We will have this out today.
