Date/Time: Fri, 03 May 2024 04:55:11 +0000
Save chartbook in different location/folder
View Count: 1700
[2015-02-24 14:42:11] |
NumbersBars - Posts: 141 |
I just updated to version 1234. When I was trying to "Save As" a chartbook, there is no option to select new location/folder. Is there any new setting I've missed out? |
[2015-02-24 18:32:55] |
This is not supported in newer versions of Sierra Chart.
[2015-02-24 22:58:53] |
And I notice opening chartbook from different location is no longer supported as well. May I know where can I change the default chartbook location? and what is the current default chartbook location? The reason of asking these questions is because my working chartbooks are stored in different folder, now I am having problem opening them. I was reading http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#SaveChartbook the documentation is not updated yet. |
[2015-02-24 23:58:26] |
Chartbooks are intended to be stored in the Global Settings >> General Settings >> Data Files Folder. Move them into that one folder. We have updated the documentation. Longer-term most likely we will put the Chartbooks into a Subfolder directly underneath the Data folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-25 00:38:41
[2018-01-11 12:53:13] |
mwnl - Posts: 29 |
I save my chartbooks in a different location and do not currently have a problem opening or closing them. Please can someone advise if it is possible to change the default location SC opens and saves chartbooks so that I do not have to navigate to the folder I use each time I launch or save a chartbook. Thanks in advance |
