Date/Time: Sun, 19 May 2024 14:15:36 +0000
Miscount with # Bars
View Count: 779
[2015-02-24 10:48:22] |
nicktrader - Posts: 665 |
In the first two screenshots is shown a #Bars Chart and part of a T&S from today (current FDax). At 09:59:50 there was triggered a Volume of 35 with a price of 11100.0 and in the second screenshot there was triggered at 10:48:57 a Volume of 37 with a price of 11106.0. From my point of view both amounts should be seen on the #Bars (see red arrows near the #Bars) but I cannot. Why is that difference or am I wrong? Please find attached also my study settings. Many thanks. |
FDax 2015-02-24 NumBars 1.png / V - Attached On 2015-02-24 10:29:35 UTC - Size: 20.58 KB - 306 views FDax 2015-02-24 NumBars2.png / V - Attached On 2015-02-24 10:29:46 UTC - Size: 36.58 KB - 329 views Study Settings #Bars.png / V - Attached On 2015-02-24 10:33:37 UTC - Size: 17.68 KB - 328 views |
[2015-02-24 18:19:49] |
Do you have any volume filtering set on the chart in Chart >> Chart Settings >> Advanced Settings 2?
[2015-02-24 18:40:58] |
no, I do not have any filter
[2015-02-24 18:45:08] |
There must be some explanation for this. Make sure you have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php The next thing to do is to actually look for that trade in Edit >>Edit/Download Data-Intraday Chart and make sure it is there. If it is, you will see it appear in Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-24 18:56:09] |
This was the explanation. It was second configured. I changed and eidt new and see the result in the attached file Thanks |
FDax 2015-02-24 #Bars after correction.png / V - Attached On 2015-02-24 18:54:29 UTC - Size: 13.69 KB - 327 views |
[2015-02-24 19:06:42] |
OK now this makes sense.
