Date/Time: Mon, 20 May 2024 14:17:11 +0000
Need below Advance Camarilla formula added to Sierra
View Count: 7199
[2015-02-23 20:24:38] |
User48942 - Posts: 9 |
Please add below Advance Camarilla formula to Sierra AT charts. H6 (1.0076*High-Low))+Close H5 (0.8244*High-Low))+Close H4 (0.555*High-Low))+Close H3 (0.275*High-Low))+Close H2 (0.183*High-Low))+Close H1 (0.0916*High-Low))+Close L1 (Close-(0.0916*(High-Low)) L2 (Close-(0.183*(High-Low)) L3 (Close-(0.275*(High-Low)) L4 (Close-(0.55*(High-Low)) L5 (Close-(0.8244*(High-Low)) L6 (Close-(1.0992*(High-Low)) |
[2015-02-26 18:50:08] |
This has now been added to Sierra Chart in the latest release and the Formula Type is 24.
[2015-02-27 13:31:58] |
Thanks for adding. But its missing H6 and L6 (i.e. R6 and S6).
[2015-02-28 06:00:06] |
avifutures - Posts: 59 |
Hi, 1. Looks like a left parenthesis is missing left to the "H" character in H1 to H6 formulas.. 2. is there a study that can put these lines on a chart ? Thx. Avi |
[2015-02-28 06:04:45] |
I found how to add it - it is Pivot Points study - Formula Type 5
[2015-02-28 06:06:15] |
I don't see formula type 24 in the pivot study doc... |
[2015-03-01 20:15:04] |
Support for support and resistance level 6 for Pivot Points formula 24 will be added in the next release. In regards to the parentheses, the calculations we have implemented are correct for formula 24. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-01 20:15:17
[2015-03-18 01:15:11] |
I have rechecked the formula again. Its not matching at all. Please recheck the formula except Support and Resistance 6. H6 (1.0076*High-Low))+Close H5 (0.8244*High-Low))+Close H4 (0.555*High-Low))+Close H3 (0.275*High-Low))+Close H2 (0.183*High-Low))+Close H1 (0.0916*High-Low))+Close L1 (Close-(0.0916*(High-Low)) L2 (Close-(0.183*(High-Low)) L3 (Close-(0.275*(High-Low)) L4 (Close-(0.55*(High-Low)) L5 (Close-(0.8244*(High-Low)) L6 (Close-(1.0992*(High-Low)) |
[2015-03-18 03:15:35] |
This is what we have: const float DR = High - Low;
R1 = Close + .0916f * DR; R2 = Close + .183f * DR; R3 = Close + .275f * DR; R4 = Close + .555f * DR; R5 = Close + .8244f * DR; R6 = Close + 1.0076f * DR; PivotPoint = Close; S1 = Close - .0916f * DR; S2 = Close - .183f * DR; S3 = Close - .275f * DR; S4 = Close - .55f * DR; S5 = Close - .8244f * DR; S6 = Close - 1.0992f * DR; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-10 01:47:48] |
User445760 - Posts: 2 |
Have there been more updates to this formula? I see 2 obvious errors that seem to need correction. |
[2016-06-10 06:18:45] |
We think we know what you mean by the errors. But before we make changes we need a good reference to validate whether this is wrong or not. Do you have any reference for us to look at? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
