Date/Time: Tue, 24 May 2022 06:39:36 +0000
point and figure
View Count: 1500
[2013-05-27 14:42:42] |
Juriossoy - Posts: 11 |
http://www.sierrachart.com/image.php?l=1369665572205.png @JY# 0.00000100 box size what I see I do not like, why? |
[2013-05-27 18:47:46] |
You need to set the Value Format in the Study Settings window for the Point and Figure study to Inherited.
[2013-05-27 19:30:42] |
thanks per answer problem is solved |
[2013-05-27 20:24:09] |
you could explain why the highs are not the same? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=505 |
Attachment Deleted. |
[2013-05-28 18:15:54] |
I noticed that the problem with PaF plus number bars does not match the highs and lows exclusively on foreign exchange instruments their format ends with by additional 00 |
[2013-05-28 22:44:52] |
When using Numbers Bars in this way you need to use Reversal Bars. Not Point and Figure bars. Please see: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ReversalBarsChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
