Date/Time: Sat, 18 May 2024 20:37:16 +0000
Time and Sales Settings
View Count: 3024
[2015-02-22 12:07:30] |
nicktrader - Posts: 665 |
I am still missing two additonal option for filtering the T&S as you can see in the attached file. Is it possible to add these two options? Thx |
Time and Sales Settings.png / V - Attached On 2015-02-22 12:05:05 UTC - Size: 25.63 KB - 1165 views |
[2015-02-24 01:07:38] |
We will see about these.
[2015-02-26 04:09:49] |
Al SC Developer - Posts: 434 |
In the next release, we added the new combining option for time and type. The num trades filtering option does not make sense though, because filtering only takes place on input records not combined records, so the number of trades is always one.
[2015-02-26 06:53:53] |
In that case I am with you but to filter a bigger block trade (i.e. 1 filter "time and type" plus 1 filter "num trades" >20) you need the num trades option.
[2015-02-27 13:59:55] |
Today I'd like to come back concerning filter option "Num Trades". In the attached file so see 3 T&S. The left one without any filter, the middle one with the filter for volume and the rght one with the new filter "with same Time and Price" (many thanks for your fast implementation). May I call your attention now on the right T&S. Because of a lack of an additional filter (num trades as a minimum) you see all trades despite if the "Num Trades" = 1 or bigger. It would be much easier if you could filter additional with "Num Trades" >= "x" and if you could filter additional with Volume this would be the best solution. As an example I "customised" the T&S Settings in the second attached file. Many thanks |
FDax 2015-02-27 with 3 Tapes.png / V - Attached On 2015-02-27 13:42:05 UTC - Size: 142.98 KB - 2195 views Time and Sales Setting new.png / V - Attached On 2015-02-27 13:42:11 UTC - Size: 24.04 KB - 859 views |
[2015-03-04 12:18:47] |
I have the feeling we get stuck at the moment. In the attached file (example...) you can see three tapes (NT example) - No 1 without any filter - No 2 with Volume filter - No 3 with Volume filter + "Alert" for Block Trades No1 and No2 is possible with the T&S Settings. No 3 is - from my point of view - restricted in terms of clearness. There is a combine filter with "Same time and type" but it is hard to distinguish a bigger block trade from the other one (as you can see in the second attached file). Isn't it possible to improve the filter for block trades? Many thanks |
Example with 3 NT tapes.png / V - Attached On 2015-03-04 11:59:47 UTC - Size: 324.15 KB - 805 views where is the block trade.png / V - Attached On 2015-03-04 12:13:32 UTC - Size: 20.62 KB - 876 views |
[2015-03-05 07:28:28] |
This is not something we have time to spend on and analyze at this time.
[2015-03-05 11:24:40] |
okay - no problem I found a "quick & dirty solution" I can live with for a while. |
T+S Setting Combine +Alert and Tape.png / V - Attached On 2015-03-05 11:22:25 UTC - Size: 38.66 KB - 1384 views |
