Date/Time: Thu, 02 May 2024 12:05:33 +0000
Chart Drawings
View Count: 769
[2015-02-20 01:50:51] |
User21113 - Posts: 62 |
Hi, A drawing is applied to a stock chart. when that chart is changed to another symbol, the drawing is still visible. Is it possible for the drawing to be visible only for the stock symbol it was applied? Example: Stock chart #1, symbol "ABC" has a line drawing applied. When stock XYZ is applied to chart #1, the "ABC" line drawing will not show. When stock ABC is applied again to chart #1, the "ABC" line drawing will show. Thanks |
[2015-02-20 03:55:19] |
Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
