Date/Time: Mon, 29 Apr 2024 15:46:51 +0000
[User Discussion] - Custom Market Profile Chart
View Count: 20266
[2020-08-23 08:13:41] |
WarriorTrader - Posts: 245 |
Thanks for you're amazing work product. I really want to expand the MP TPOs. However, I'm using v2156 and I've received a message that the .dll needs to be recompliled for v2156. Can you help?
Hello, Here is a version compiled for SC version 2115. That should be good enough. Let me know if you have any problems. Use the sample chartbooks in post #94 and #95: Custom Market Profile Chart | Post: 208385 Custom Market Profile Chart | Post: 208386 Letter Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=36158 Block Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28515 Good Trading, -WT |
CustomProfile_U_64.dll - Attached On 2020-08-23 08:09:48 UTC - Size: 140 KB - 311 views CustomProfileFillSpace_64.dll - Attached On 2020-08-23 08:12:27 UTC - Size: 95.5 KB - 296 views |
[2020-08-23 12:18:56] |
Ackin - Posts: 1865 |
Sorry but this version will not work for anyone from version 2151. All user studies must be recompiled for new versions of SCH. In good ... look: ................... The most important thing to understand is that this version breaks compatibility with existing compiled custom studies. Custom studies have to be rebuilt on 2155 or higher to use them with 2155 or higher. Although the change occurred at version 2151, there were subsequent changes and now ACSIL custom studies have to be recompiled using Sierra Chart version 2155 or higher. and here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156 Date Time Of Last Edit: 2020-08-23 12:20:51
[2020-08-28 06:41:01] |
Hello, Here is a version compiled for SC version 2159. Let me know if you have any problems. Use the sample chartbooks in post #94 and #95: Custom Market Profile Chart | Post: 208385 Custom Market Profile Chart | Post: 208386 Letter Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=36158 Block Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28515 Good Trading, -WT Date Time Of Last Edit: 2020-08-28 06:48:02
CustomProfile_U_64.dll - Attached On 2020-08-28 06:40:03 UTC - Size: 139.5 KB - 396 views CustomProfileFillSpace_64.dll - Attached On 2020-08-28 06:40:28 UTC - Size: 95.5 KB - 357 views CustomProfile_Letters.png / V - Attached On 2020-08-28 06:47:29 UTC - Size: 91.59 KB - 469 views |
[2020-08-28 06:49:09] |
File attached
CustomProfile_Block.png / V - Attached On 2020-08-28 06:48:58 UTC - Size: 60.88 KB - 486 views |
[2020-08-29 23:20:08] |
UserV-Werks - Posts: 4 |
Warrior Trader, Thank you so much! Everything is working as expected! |
[2022-04-26 06:05:41] |
Hello, My original custom profile became obsolete once SC incorporated the ability to display two profiles of the same day, but there are still some things that the study can be used for. I have added letter labels for the block profiles that are displayed in separate columns. You can get a lot more price data on the screen with a block profile but you have no way of knowing what letter the period is – until now. You can use the example chart to see how the study is set up. It involves one chart to load the study and then a second chart that the custom profile can be projected to. There is also a brand-new study that displays these labels on a TPO Profile Chart that will be posted after this one. Good Trading --WT SC version: 2383 |
Custom Profile Example.Cht - Attached On 2022-04-26 06:01:48 UTC - Size: 9.81 KB - 175 views CustomProfile_U_64.dll - Attached On 2022-04-26 06:02:10 UTC - Size: 142.5 KB - 194 views Custom Profile 2.png / V - Attached On 2022-04-26 06:03:19 UTC - Size: 89.5 KB - 222 views |
[2022-04-26 06:13:16] |
Here are some more examples along with a supplemental study that will add fill space every 30 minutes to accommodate new columns. --WT Date Time Of Last Edit: 2022-04-26 06:57:17
CustomProfileFillSpace_64.dll - Attached On 2022-04-26 06:09:37 UTC - Size: 95.5 KB - 170 views Custom Profile.png / V - Attached On 2022-04-26 06:11:03 UTC - Size: 59.46 KB - 192 views Custom Profile 3.png / V - Attached On 2022-04-26 06:11:36 UTC - Size: 79.79 KB - 195 views |
[2022-04-26 06:53:11] |
Hello, Here is a brand-new study that displays letter labels on a TPO Profile Chart. Every time you select or unselect “Letters/Blocks in own column" new labels will be drawn under the new columns. You can also choose to project onto a remote chart the current day's high and low for each period. This will allow you to combine time frames. You can get much more price data displayed with a block profile but there is no way of knowing what letter the period is - until now. Just like the original Custom Profile, this study uses two charts. The first chart is a bar chart that matches the time period of your profiles (usually 30 minutes) (load the study on the first chart) and the second is the actual SC profile chart (TPO Profile Chart). Use the example chart book to see how it is set up. Good Trading, --WT SC version: 2383 |
Custom Profile Example.Cht - Attached On 2022-04-26 06:42:41 UTC - Size: 9.81 KB - 177 views CustomProfileBlockLabel_64.dll - Attached On 2022-04-26 06:43:03 UTC - Size: 140.5 KB - 195 views Custom Profile - Column Labels.png / V - Attached On 2022-04-26 06:44:39 UTC - Size: 73.26 KB - 237 views |
[2022-04-26 06:55:41] |
One more picture demonstrating the remote High/Low Labels. --WT |
Custom Profile - Period High and Low Labels.png / V - Attached On 2022-04-26 06:54:54 UTC - Size: 63.93 KB - 249 views |
[2023-01-31 16:41:11] |
MarcOh - Posts: 162 |
hey warrior, is this study still valid? thx. |
[2023-03-13 02:32:51] |
hey warrior,
is this study still valid? Well I have not compiled a new version in a while. It should be fine. I will compile a new version for 2448 soon. Thanks, -WT |
[2023-12-28 20:40:57] |
Hello, Here is the Custom Profile Block Label study compiled in SC version 2543. If the copy you are using is running, there is no need to upgrade to this one unless you want to use the new feature. If you are running 2551 or higher, it may not work. Let me know if it fails. There is a new feature that allows you to use letter labels on a bar chart. I don’t expect many people will use this but it was requested. Look at post #107 to see detailed explanation of this study: Custom Market Profile Chart | Post: 304866 The study adds letter labels to a block TPO Chart when “Letters/Blocks in own column” is selected in SC. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=63743 Good Trading -WT |
Custom Profile Example.Cht - Attached On 2023-12-28 20:30:12 UTC - Size: 13.94 KB - 46 views CustomProfileBlockLabel_64.dll - Attached On 2023-12-28 20:31:01 UTC - Size: 144 KB - 147 views Custom Profile - Column Labels.png / V - Attached On 2023-12-28 20:35:21 UTC - Size: 73.26 KB - 46 views |
[2023-12-28 20:49:12] |
Hello, Here is the Custom Profile study compiled for SC Version 2543. If you are not having any problems with your version of the study, there is NO need to upgrade to this one. If you are running 2551 or higher, it may not work. Let me know if it fails. Use the Custom Profile Example.cht to learn how to use the study or scroll up to find some explanations. Good Trading -WT Date Time Of Last Edit: 2023-12-28 20:50:17
Custom Profile Example.Cht - Attached On 2023-12-28 20:46:20 UTC - Size: 13.94 KB - 119 views CustomProfile_U_64.dll - Attached On 2023-12-28 20:47:01 UTC - Size: 144 KB - 52 views Custom Profile 2.png / V - Attached On 2023-12-28 20:47:51 UTC - Size: 89.5 KB - 53 views |
[2023-12-28 20:52:49] |
Date Time Of Last Edit: 2023-12-28 21:09:46
Custom Profile.png / V - Attached On 2023-12-28 20:51:13 UTC - Size: 59.46 KB - 70 views Custom Profile 3.png / V - Attached On 2023-12-28 20:51:50 UTC - Size: 79.79 KB - 76 views CustomProfileFillSpace_64.dll - Attached On 2023-12-28 20:52:24 UTC - Size: 95.5 KB - 49 views |
[2024-01-04 15:34:03] |
File attached
CustomProfileFillSpace.cpp - Attached On 2024-01-04 15:33:32 UTC - Size: 2.18 KB - 131 views |
