Date/Time: Sun, 05 May 2024 15:10:31 +0000
SC datafeed new contract setup
View Count: 847
[2015-02-19 16:02:10] |
User22396 - Posts: 191 |
pls add: nymex chicago ethanol (platts) futures globex symbol CU cbot ethanol futures globex symbol EH these are fairly illiquid but i have a project i am working on and need access to the historical data thanks |
[2015-02-19 17:30:26] |
Do you need historical Daily or Intraday data?
[2015-02-19 17:51:46] |
just historical thanks
[2015-02-19 18:15:51] |
The only available ethanol futures contracts which provide historical daily data are listed here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
