Date/Time: Thu, 02 May 2024 19:34:15 +0000
Teletrader | Symbol Lookup VSTOXX
View Count: 914
[2015-02-19 13:51:44] |
User10875 - Posts: 42 |
Hello, I am trying to find the VSTOXX index with TeleTrader. The symbol is V2TX (according to STOXX.com). I have tried to find this index , using the search by Decs button and using different exchanges (ETR_T105 | Indices Xetra and FRA_T105 etc..) Is there a way to list all available symbols when selecting an exchange, or even better all symbols available irrespective of the exchange selected? Kind regards SH. |
[2015-02-19 18:33:22] |
It would make most sense to search for VSTOXX by description
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-19 18:34:57
[2015-02-19 20:05:51] |
This is what I did as well (search for VSTOXX by description) before writing my last post. It´s difficult to find the right symbol if you do not know the exact name. For instance, all STOXX indices could also start with D (D for Dow). Same problem with all TeleTrader market internals. That´s why I am asking: Is there a way to list all available symbols irrespective of the exchange selected? This would save a lot of time and avoid posts on the support boad. Kind regards SH. |
[2015-02-19 20:09:53] |
There is no way to list all symbols for an exchange with TeleTrader. And certainly there is no way to list all symbols for TeleTrader because that would be too overwhelming. You have to type at least a single letter when searching for a symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
