Date/Time: Fri, 03 May 2024 18:43:34 +0000
[User Discussion] - market profile
View Count: 1950
[2015-02-18 18:43:41] |
User981697 - Posts: 32 |
hi i trade the es mini sp and I want to set the time to the beginning of the graph of Markt Frofiil ..ham starting from the beginning to the end of the day or only from the beginning of trading on Wall Street 16: 15-9: 30 ? Date Time Of Last Edit: 2015-02-18 20:48:45
[2015-02-18 20:32:43] |
Zosimus - Posts: 345 |
You can create any session you want. Look here: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php |
[2015-02-18 20:35:00] |
ok and the tpo on the market profile has to be 0.50*30min or 0.25*30min?
[2015-02-18 20:41:03] |
for a "regular" TPO profile: Letter/Block Price increment in ticks: 1 Profile time period length: 1 Profile time period lenghth unit :days. Number of TPO profile periods : Multiple periods fixed by time TPO Letter/block time period length in minutes : 30 |
[2015-02-18 20:49:12] |
Looks like posts #2 and #4 answers your question. Let us know if you need more help.
[2015-02-19 19:36:24] |
ok and the vah and val are not the same 0.50*30min its 0.25*30min its have to be the same like the tpo? |
ללא שם.png / V - Attached On 2015-02-19 19:36:06 UTC - Size: 277.68 KB - 455 views |
[2015-02-19 20:18:10] |
way the vah and val not the same at the tpo chart?
[2015-02-19 20:20:07] |
the chart
ללא שם.png / V - Attached On 2015-02-19 20:20:02 UTC - Size: 247.8 KB - 402 views |
[2015-02-19 20:23:05] |
and chart
ללא שם.png / V - Attached On 2015-02-19 20:23:03 UTC - Size: 123.16 KB - 389 views |
[2015-02-19 20:35:04] |
If I am not mistaking the bars chart doesn't have the same sessions settings as the tpo chart so obviously you are getting a different value area.
Date Time Of Last Edit: 2015-02-19 20:35:24
[2015-02-19 20:44:22] |
ok you righte
[2015-02-21 09:30:53] |
i dont anderstend why the val and vah is not the same////
ללא שם.png / V - Attached On 2015-02-21 09:30:32 UTC - Size: 329.84 KB - 403 views |
[2015-02-21 09:37:36] |
the attached
ללא שם.png / V - Attached On 2015-02-21 09:37:30 UTC - Size: 314.93 KB - 386 views |
[2015-02-21 11:48:26] |
I am very confused with regard to the time I was supposed to implement in Market Profile ... I am a dealer from Israel so what are the times I have to fill out in the setting???I should also nead evening session.
Date Time Of Last Edit: 2015-02-21 11:52:40
[2015-02-21 12:25:13] |
that depends on what time zone your sierra chart is using. Go to File >> Data/Trade Service setting and tell me what time zone you are using. Date Time Of Last Edit: 2015-02-21 12:33:16
[2015-02-21 15:51:14] |
its chicago times
[2015-02-21 15:51:15] |
its chicago times
[2015-02-21 15:52:37] |
there is no israrl or jerosalem time
Date Time Of Last Edit: 2015-02-21 15:53:17
[2015-02-21 16:30:32] |
this is getting complicated. Date Time Of Last Edit: 2015-02-22 18:30:28
[2015-02-21 17:09:04] |
Since you are trading futures contracts my advice to you is to use Chicago Time Zone. This way you will not have problems with daylight saving times in the summer. If you use Chicago then: Day session: 8:30 - 16:15 Night Session: 17:00 - 8:29:59 If it is important for you to use Israel time zone then Choose Other/Custom DST and set it to +2 and set the summer time hours to: From 27.3.2015 2 am Until 25.10.2015 2 am |
[2015-02-21 19:33:33] |
ok yon thenks very mutch
[2015-02-21 19:35:24] |
i will call tomorohe
[2015-02-21 19:55:35] |
whats your email?
[2015-02-21 20:07:06] |
yon can you look at this page ,its write difrent hour
ללא שם.png / V - Attached On 2015-02-21 20:07:00 UTC - Size: 112.08 KB - 408 views |
