Date/Time: Tue, 21 May 2024 12:15:41 +0000
Issue with one instrument for Sierra datafeed
View Count: 806
[2015-02-18 13:58:05] |
darkpool - Posts: 39 |
Hi, Please advise if there is currently an issue with the Sierra live datafeed specifically on the CME 10 year (ZN). Other instruments are updating correctly, eg: ES However the ZN prices are not updating. I have tried opening a ZN chart as well as a ZN quote board. It appears as though im not receiving ZN data for some reason. I do not see any errors in the log. Thank you. Date Time Of Last Edit: 2015-02-18 13:58:27
[2015-02-18 14:24:36] |
Please see attached screenshot taken at 08:21 CST. The quote board contains the ES and ZN. As you can see the ES is fine. Last trade time is 08:21. Something is wrong with the ZN. Last trade time is 18:03 Thanks. |
Capture.PNG / V - Attached On 2015-02-18 14:24:08 UTC - Size: 42.27 KB - 293 views |
[2015-02-18 16:44:22] |
MKL17 - Posts: 35 |
I am also having the same issue regarding ZN
[2015-02-18 17:23:38] |
User98316 - Posts: 10 |
ZB had also stopped updating.
[2015-02-18 17:35:33] |
xRoads1 - Posts: 35 |
Having the same problem with ZB
[2015-02-18 17:54:42] |
This has been resolved. It was a problem on one of our servers. We do apologize for the delay with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
