Date/Time: Tue, 21 May 2024 14:31:14 +0000
Importing a layout file
View Count: 805
[2015-02-18 10:53:32] |
User66329 - Posts: 1 |
Have been trying to import both these files to sierra to no avail.Hopefully you can help
Private File Private File |
[2015-02-18 19:47:02] |
Select Global Settings >> General Settings. Make a note of the Data Files Folder. Save these files to that folder and contact whoever provided them to you for instructions on how to use them.
