Date/Time: Sun, 19 May 2024 00:03:00 +0000
autostart quote spreadsheet when starting SC
View Count: 732
[2015-02-17 17:19:29] |
Eric Cartman - Posts: 16 |
Hi, ist it possible that a saved quote spreadsheet is opened directly (in a detached window) when SC is started ? Just like a regular (detached) chart ? Thank you ! |
[2015-02-17 17:57:01] |
Yes. Global Settings >> General Settings >>Files to Open on Startup
