Date/Time: Sat, 18 May 2024 20:20:44 +0000
Order Line Length
View Count: 1183
[2015-02-17 11:21:26] |
User96267 - Posts: 43 |
Dear SC, is it possible to scale the order line length in the chart? Best regards! |
[2015-02-17 17:48:52] |
There is a setting for this in Chart >> Chart Settings: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TradeDrawingsLeftAlignPercent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-17 18:31:43] |
Thank you! Exactly what I wanted.
