Date/Time: Sat, 18 May 2024 19:51:01 +0000
Sierra crashes
View Count: 810
[2015-02-17 10:50:46] |
jbetlach - Posts: 30 |
Whenever I touch Graphics settings under Chart menu trying to change something, Sierra crashes. It happens just with graphics settings, no problem with other menus or other operations. Any idea? Thank you |
[2015-02-17 10:53:47] |
This is only with the prerelease and it has been solved. Update Sierra Chart again with Help >> Download Prerelease.
[2015-02-17 10:56:12] |
Oh, OK. Thank you |
