Date/Time: Sat, 18 May 2024 20:43:50 +0000
Volumw by Price bug ?
View Count: 814
[2015-02-16 15:05:56] |
crazybears - Posts: 314 |
Hi all of a sudden Volume by price shows holes , where till yesterday there wasn't , i tried to download data again but holes are still showed http://www.sierrachart.com/image.php?l=1424099080419.png Date Time Of Last Edit: 2015-02-16 15:06:17
[2015-02-16 15:09:22] |
SC V 1232
[2015-02-16 16:29:53] |
ok sorry i haven't seen , you added others levels and set color to black :-| |
[2015-02-16 17:07:01] |
Yes, this is the problem. The default color is not black but when you update and you have an existing Volume by Price study, they will be black. In the next release when you update, those colors will all be set to the Volume Bar Fill color, but after that you can change them back to your own colors and they will remain. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
