Date/Time: Sat, 18 May 2024 20:20:20 +0000
High/Low for a Time Period Study
View Count: 882
[2015-02-15 22:29:41] |
conr - Posts: 204 |
Are you able to add an option for the study to always be in view for the value labels and extend the lines for the full period? I use the study to set high/low for first hour of trading and the lines do not extend beyond that first hour. Thank you. |
[2015-02-15 22:33:13] |
Use the High/Low for Time Period-Extended study instead.
