Date/Time: Sat, 18 May 2024 14:45:11 +0000
[User Discussion] - TradeDOM Columns
View Count: 1444
[2015-02-15 14:55:16] |
User96267 - Posts: 43 |
Dear SC-Team, I want to configure the TradeDOM columns of each Trading DOM. But it seems to me that every DOM has the same columns. Is it possible to configure each Trading DOM individually? That would be really helpful! Thank you very much! |
[2015-02-15 18:28:27] |
Tried it through "Customize TradeDOM Columns". Everyime I change it for one DOM, it appears in every other DOM. Is it possible to avoid it? |
Screenshot_1.png / V - Attached On 2015-02-15 18:28:24 UTC - Size: 46.1 KB - 353 views |
[2015-02-16 07:40:52] |
Anyone?
[2015-02-16 14:07:10] |
Any suggestions? I would be very thankful. A short statement if this is possible would be nice. Otherwise this support ticket can be closed. |
[2015-02-17 03:02:17] |
No, it is not possible to configure the Chart/Trade DOM columns individually for charts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-17 03:02:42
[2015-02-17 06:31:46] |
Thank you. Is there a Release in the future where it is planned?
[2015-02-17 17:51:14] |
No. This is not planned.
[2015-02-17 18:31:18] |
Ok, is it possible to reset the recent bid/ask trades of ALL doms via hotkey?
